DeltaV Simulate v11.3 Installation
Some time go I successfully installed DeltaV Simulate (stand-alone) on a Dell Latitude D830 laptop under Windows 7 Professional.  I don’t recall having any problems with this.  As this machine has now become clogged with other stuff, I re-installed Windows 7 Professional and attempted to install DeltaV v11.3.  The installation goes so far and then fails with the error message shown below.  Any assistance in resolving this would be most welcome as I’m now stuck without a DeltaV development and test system.
Neil Brown
______________________________________________________________________
This email has been scanned by the Symantec Email Security.cloud service.
For more information please visit http://www.symanteccloud.com
  • Try responding “No” to the retry dialog shown below, restarting Windows, and then initiating another DeltaV Simulate install.  (This worked for me once.)
    Duane
    Sent: Wednesday, September 05, 2012 11:58 AM
    To: [email protected]
    Subject: [EE365 DeltaV Track] DeltaV Simulate v11.3 Installation
    Neil Brown
  • Thanks, Duane.  It didn’t work for me though.
    Anybody got other suggestions?
    Neil Brown
    Sent: Wednesday, September 05, 2012 6:23 PM
    Subject: RE: [EE365 DeltaV Track] DeltaV Simulate v11.3 Installation
    Duane
    Neil Brown
  • In reply to neilrbrown:
    Try manually installing SQL first from the DeltaV DVD and then try DeltaV Simulate install again.
    If that doesn't work you may be forced to reinstall the OS.
    Good luck,
    Matt
  • You have window 7 professional SP1 loaded, right?
    Deb Colclazier
    Automation Engineer
    DCS System Admin
    803  US Hwy 212 S.
    Laurel, Mt.  59044
    406-628-5528 – office
    406-633-3343 – cell
    Sent: Wednesday, September 05, 2012 2:01 PM
    Subject: Re: [EE365 DeltaV Track] DeltaV Simulate v11.3 Installation
    Neil Brown
    Duane
    Neil Brown
  • I keep DeltaV in a virtual machine (e.g. VMWare). You can keep your DeltaV Simulate clean and lean and not worry about clogging it up with other stuff on the laptop or having the wrong updates, etc.
  • I agree with going VM.  I have 3 development systems for my plant on VM.  You still need the right OS.
    Sent: Wednesday, September 05, 2012 5:38 PM
  • Thanks, Deborah.  I re-installed Win 7 from the original disc, but I don’t know what service pack it is at.  I’m travelling at the moment and my other laptop is at home, so I won’t be able to progress this further until Monday.  The OS setup is exactly the same as that on which I originally installed DeltaV Simulate though.  Very odd...
    Neil Brown
    Sent: Wednesday, September 05, 2012 10:47 PM
    Deb Colclazier
    Automation Engineer
    DCS System Admin
    803  US Hwy 212 S.
    Laurel, Mt.  59044
    406-633-3343 – cell
    Neil Brown
    Duane
    Neil Brown
    I also agree that a VM is the best option here, but if you insist on installing on the host machine then I sugget deleting the SQL database for the EVENT CHRONICLE first manually. If that does not work neither then remove the SQL components completely and re-install everything.
    Marko
  • Thanks to all who responded to my request for help on re-installing DeltaV Simulate.  Unfortunately, none of the suggestions worked!  However, I have managed to resolve the problem.  In case anybody else has had similar difficulties, here is what worked for me.
    • First I did a ‘clean install’ of Windows (i.e., format the hard disk partition before installing Windows).  In my case I installed Win 7 Home Premium then a ‘Windows Anytime Upgrade’ to Win 7 Pro – but I don’t think this is relevant.
    • Then I downloaded and installed Win 7 Service Pack 1 from the MS website.
    • Once this was all done, I installed DeltaV and all went OK apart from an error message almost at the end of the process.  I ignored this and all seems fine.
    My guess is that the ordinary re-install process for Windows (i.e., without formatting the disk partition) leaves some residual stuff that was getting in the way of DeltaV.  I didn’t really want to take the time to learn how to use VMWARE (I’m a process and controls engineer, not a software engineer), but agree that a virtual machine is a good idea.
    Best regards,
    Neil Brown
    Sent: Thursday, September 06, 2012 11:32 AM
    Marko
