Hello,
I have to used on project modified ControlModule from PCSD for PWM control (called _C_PWM_V01). After some minor difficulties I got the block working.However, after adding a graphic representation to the screen (also from the PCSD library "PCSD_CtrlValve_v01_), the valve is displayed in purple because the ControlModule does not contain an AO block. How do you solve this situation?
Thank you for your experiences.
Take care
Tomas Grepl
In reply to Matt Stoner:
In reply to Tomas Grepl:
