I'm trying to use bulkedit to mass create new modules. It regularly fails whenever it hits a "°F" even though it is in my engineering units file, and looks correct in the text file. Its such a common character, I'm hoping someone has a workaround for this? I already tried making the default units in the module subtype template "°F"
Updating Type: MODULE: Name: TI_8133ZSB1: WARNING: The parameter 'AI1/IO_IN' is not found on the function block definition 'TI_8133ZSB'. It is ignored in the context of this usage ''2: WARNING: Importing ATTRIBUTE_INSTANCE1: WARNING: The name '░F' was not found in this context2: WARNING: Unable to set engineering units for scaling parameter value3: WARNING: IMPORT ERROR: IMPORT of MODULE with key TI_8133ZSB FAILED at line:2723 column:51. This could cause other serious import errors for related items in this file. Import is now resuming at the next item in the file.
I'm working on V15 today, but I've run into this on several versions of deltav.
In reply to Jesse Delanoy:
In reply to Cedric Dawnhawk:
