We have a customer struggling with audio noise in the control room, with multiple consoles, each with Radio stations, DCS consoles (alarms), Public Address announcements and such. Each console can have several people engaged in discussion, which leads Operators to turn up their audio outputs, which leads to every increasing levels of noise, making everything difficult to hear.
One solution proposed was the use of directional speakers in each console in a control room, but with multiple audio sources per console, having multiple speakers still creates noise competition. We were asked if there was a solution that would allow multiple Audio sources to be connected together where a priority could be set on the input signals such that when two or more signals are present at the same time, the system can reduce the audio level based on priority to ensure the priority audio signal is clear. The other signals return to normal based on priority, resulting in a quieter environment and one directional speaker per console.
I thought I'd ask the community to see if this type of solution already exists. With today's technologies it seems quite plausible that a multi input audio device could detect signal levels/presence and auto adjust channel gain to prioritize the Alarm Horn over Radio, but the Radio over the PA or other audio signal. With one directional speaker per console to manage, the ambient noise level would drop, allowing conversations to also remain at lower volume.
What do you do in your control rooms and consoles to manage noise levels?
In reply to István Orbán:
