VIM Ethernet Device Configuration Data
dave_marshall
13 May 2024 5:28 PM
List of Logged in Users on HMI
TPatterson
9 May 2024 6:47 PM
Enable and disable alarms on a workstation based on which user is logged in
Mohd Ramdhan Ramli
6 May 2024 12:22 AM
DeltaV gave Windows error "Not enough storage is available to process this command"
gbilly
3 May 2024 4:53 PM
Troubleshoot and configure Modbus
Valentin Borsu
1 May 2024 5:31 AM
VIM 2 Communication with ControlLogix - with Embedded EtherNet Port
VIM CONFIGURATION FOR POWERFLEX 525 WITH DELTA V SX USING VIM
VIM Communication Errors, Ethernet Frame Check Sequence Failure
Lost VIM configuration file(VIO) and completely forgot VIM IP address
VIM vs EIOC for MCC/Switchgear Integration (EtherNet/IP a& 61850)
Dear All
At Book Online, VIM Ethernet Device Configuration Data just for 2 type of PLC (PLC5 and SLC 505).
Any other type of PLC support VIM?
Thank you all
Best Regard
Arifin Purwanto
DBacker
28 May 2015 1:05 PM
What type of PLC are you using?
You should check the Mynah Technologies website for the VIM manuals. There are at least 2 manuals. Ethernet/IP and Modbus TCP.
For Ethernet/IP they have at least 2 types of communications. One is UCMM Client (I think they also call this Class 3) with DF1 encapsulation to communicate with SLCs and PLC 5 (uses typical Allen-Bradley N, F type register addresses). Control Logix can also do this. There is a separate section in Control Logix for mapping to PLC5 register addreses. Control Logix can also communicate via what is called a Class 1 servier. This can make the VIM look like logix I/O.
