It is a pain when the process leaks thru the packing & safety becomes a concern to those working around the plant.
Do you wish that you do not have to maintain & adjust the packing every now & then. A valve with a maintenance free packing will solve your issues & give you a peace of mind!
Have you heard of enviro-seal packing system?It helps you to conserve valuable process fluid inside the body while reducing emission to the environment…. They are available in all Fisher valves & certified for a broad range of service conditions. They are also tested & certified to ISO 15848, ANSI 91-1 & TA-Luft.
If safety is a concern & ultimate protection against leakage is required then you have the option of enviro-seal bellows.
So good to be even true? ….. pls click on the link to find out more
http://www.documentation.emersonprocess.com/groups/public/documents/brochures/d351050x012.pdf
