EE - Forum Styles
fo
BAUMANN Valve Identification
Hi, my name is Diego and I would like to get more info about a valve that is critical for my process, I checked this valve in the field and the only thing that I get was in the valve body:
 -  1 1/2 IN - 250  B62
-  011943 - 1 BAUMANN
I would like to know the tech specs of this valve, but there is no manuals, the shop is a mess.  Please help me to know the tech specs of this valve,
thanks in advance
  • Hi Diego,
    If you have 375/475 communicator, you can find the serial No in the DVC6000, send it to Fisher. They can find information you need.
    Regards
    Daniel
    在2013年06月28 12时08分,"Diiego Barrigaa"<bounce-DBarrigaa@community.emerson.com>写道:
    thanks in advance
    Daniel Qi Lou
  • Anonymous
    Anonymous
    In reply to qi lou:
    Thanks for answer!
    But the DVC6000 is from another valve, we replaced the old one that came with the valve for this new one
  • In reply to Anonymous:
    Hello Diego:
    Without a specific serial number or order number, an exact construction cannot be determined.  Serial numbers are usually:  stamped into the body near bonnet or flange end and/or indicated on an attached SST nameplate (can be on valve or actuator).
    For more general specifications and instructions, documentation can be found here (copy & paste into browser):
    www.documentation.emersonprocess.com/.../idc_cgi_isapi.dll
