I wanted to share this Q&A I had on the Emerson Process Experts Facebook group with this community:
Greetings, on a Schafer actuator are both the solenoid and limit switch terminal strips in the same housing. Do I only run a single conduit ? Thanks
Here's the response I received back from my friend on the Valve Automation team:
Normally any solenoid valves associated with the equipment are terminated back to a terminal block that is located inside the limit switch enclosure so only one single conduit run is required.
If anyone else has anything to add, please weigh in.
