Hello All,
I would like to know if its applicable or not to show the volume on the display unit for a pro and rex gauges ?Note: we have a tank master and the straping points are entered for each tank on win opi
Regards
Yes, The standard view on a RDU40(REX) or 2210(PRO) shows Level, ullage, volume, level rate, signal strength and average temperature There are over 20 variables to chose from and you can set a user defined view with any six of those toggling at a certain interval. Configure via the push buttons or Win setup.
In reply to boxyman:
Take a look at the manual from the official website. Shows the procedure fairly well. push buttons on display actually the easiest way if you have time to walk around to the tanks. www.rosemount-tankradar.com/.../rdu40_rex_UG_ed2_308010EN.pdf
