I read in the manual about the Calc Editor in which an example is given about "SYS PEER CRITICAL". Paragraph 8.3.3 shows a description about the Calc Editor as "Special Edit"
I understand you can add and delete inputs and outputs, but how do I know which inputs are required. I can delete for all calculations all inputs, and Config600 will not complain. But without inputs you can't do any calculations. And add an additional input will not be understood automatically by the selected function.
Is there somewhere a document/help file in which is specfied which inputs and outputs are required for each function? Or in case I completely misunderstand the "Calc Editor" more information about how to use it.
In reply to ian firth:
In reply to Martijn Groot:
