EE - Forum Styles
fo
micromotion f300 clogged by cement
hello Team,
I have micromotion f300 clogged by hard cement, I want to know if there is a way to clean it.
Best Regards
  • Thanks for writing! If the cement is soluble in an acid or other solvent, etc. then it’s possible. Otherwise, I’m afraid the meter may need to be replaced. Please check for material compatibility- most likely your meter is constructed of 316L ss, so it does not like certain acids (HCl in particular)
    Best of luck!
    Tom O’Banion
