Roxar FSM Log 48 Area Corrosion Monitor for Corrosion and Erosion Monitoring
Emerson launched the Roxar FSM Log 48 Area Corrosion Monitor this autumn and along with that we wrote several articles on the dangers of corrosion and erosion to pipeline integrity.
In this blog post we summarize the key points of those articles to give you a snapshot of the information presented and to introduce you to the Roxar FSM Log 48.
Oil and gas pipelines often run across great distances and at times through remote locations; 2,175,000 miles of pipeline in 120 countries around the world. Monitoring those lines for internal corrosion is a considerable – but necessary – task, knowing that internal corrosion is one of the main cause of incidents and that the majority of the pipelines are over 20 years old.
Today, up to 70% of pipeline inspections for leaks are done visually, but that doesn’t give any indication of the metal loss rate  that might be happening inside the pipe nor its morphology, it merely shows that metal loss hasn’t gone too far and caused a leak. This is where non-intrusive area monitoring based on the Field Signature Method (FSM) is a valuable tool to enhance pipeline integrity management programs, help avoid operating expenses related to excessive in-line inspection and reduce capital expenditure related to late maintenance.
FSM technology is based on feeding an electrical current through a monitored section of pipe, pipeline or vessel. The applied current sets up an electrical field that is monitored as voltage drop values between a set of sensing pins installed on the external pipe wall. These values are then converted into easy-to-understand corrosion information.
Roxar FSM Log 48 Area Corrosion Monitor provides not only average metal loss rates of the monitored area but also a three-dimensional representation of the corrosion phenomena, which can help identify localized and generalized corrosion.
To learn more, explore the highlights and benefits of the Roxar FSM Log 48 , visit the product page on Emerson.com, or watch the Roxar FSM Log 48 Area Corrosion Monitor video!
The post Roxar FSM Log 48 Area Corrosion Monitor for Corrosion and Erosion Monitoring appeared first on Emerson Flow Solutions.
