COMM-D / PowerFlex 70 VS 753 Device Net Programing Problem
I am having an issue adding one of our VFD's to device net. For our powerflex 70's we use the COMM-D adapter. for our PF 753's we use the  20-750-DNET adapter. I was able to successfully map out all the I/O's on our PF 70 using the Comm-d manual (Appendix D) except the start and stop command.  With our 753's we map the DST as follows,
Output, Boolean
First Bit - 2
Used Bits - 1
Byte Offset - 2
With this configuration we are able to start and stop the motor/pump using only one DST. When I try this with out PF 70's it dose not work. Looking at both manuals I believe the command start/stop I/O is the same. Can anyone shed some light on this?
Tom
