Pretty new at the graphic portion of delta v 11.3.1. I have a normally open valve but the graphic is responding like a normally closed valve. Am I missing something shouldnt there be a easy way to convert this graphic to have the color changes respond like a normally open valve. What i mean is the colors need swapped 100 percent is showing green and not allowing flow, while zero percent valve is showing red and showing flow. I need these to be swapped where they react differently. The control module seems to be working. Is there a quick and easy way to fix this.
