FF device commissioning issue
We have a "Rosemount Analytical (1066 CT-FF Rev 1) " in a decommissioned node. When we try to Commission the device we get following error. "The name FB001400 is already used inn the context"
  • Tried to directly drag and drop from decommissioned node to Port and then create the placeholder.
  • Also tried to first create the Placeholder. But the placeholder itself doesn't get created when we select Device type as 1066 CT-FF.
  • We have proper DD file of Rev 1 present  in both Deltav Explorer (10.3.5) and in AMS device manager (12.5.7).
  • We have also installed DD files again but the error remains.
  • FF device has been done power reset too. Error is the same
This error we are facing only for this type of device. Other devices on same JB are already commissioned successfully. What can be the issue that only this device is getting such type of error? Is there anyway to find out where actually " FB001400" is used in the database because we did a search but didn't find any reference for such block.
Regards.
Muzammil
