Hi everyone, I have some issues with this error, I'll try to explain the best as possible:
I'm actually working in a pharmaceutical plant in which we have two DeltaV Systems the old one is ver 11.3 and the new one is ver 13.3 which hasn't been delivery yet (emerson people are still working on batch logic control).
The DV system ver 13.3 had the workspace application error number 5(5) when the "search utility" button was pressed, I solved this problem by modifying the "MODT.SCR" cause had the next structure:
MODTI { NAME='module' DEVID=############# AREA=# CDISP='display' IDISP=
'faceplate' DDISP='detail' DESC='description' }
I modified it in the next way:
MODTI { NAME='module' DEVID=############# AREA=# CDISP='display' IDISP='faceplate' DDISP='detail' DESC='description' }
I changed that file in all the workstations of the new DV System and now we are able to use "Search Utility" button with no problems.
But this problem is presented in one operator station of the old DeltaV (11.3) the problem here is when I press the "Search Utility" button in that station appears the window with the message of the error number (5) and it doesn't matter how many times I close de windows it keeps appearing and I'm not able to use DeltaV Operate because of that window, I have to log off the station so windows force the shutdown of DeltaV Operate, I checked the MODT.SCR in this station and it looks normal with the right structure:
It's strange because in the proplus I don't have this problem and I'm able to open the "Search Utility" without any problems.
Somebody has any advice to fix this issue?.
In reply to Andre Dicaire:
