We recently started an install AMS 14.1
We install the Server+ first and then the ProPlus (wheren the Client is install). The issue we had was that the Server+ was in a domain and the Client was not. We still having issues connecting between Server+ and Proplus(Client) (Deltav).
After thinking that was an issue we remove the PC (Server+) out of the domain (now a workgroup) to be the same as the Proplus(Client). These two are separated by a Firewall. We open all the necessary ports, so we can ping the two. On the Server+ everything seems to be working but is on the Proplus we are having problems.
We contacted the technical support but they told us that this architecture is not supported since there is not domain.
Can someone have a similar setup ? Also, on both PCs we added the same User and Pass.
Thanks!!
In reply to Tinh Phan:
In reply to Santiago Vera Torres:
There are several things you might want to check if the ping are working.
