We have a contractor that configured motors using a DC1 block with EIOC I/O. We need the ability to have the stop output to the motor to be only a momentary true bit. So when the motor goes to start again the stop output is already false then the motor looks for the positive edge of the start bit. Is there a way to have the EIOC output be a momentary true like physical Discrete outputs?
