Using DeltaV as a Burner Management System
I am interested in the specifics of using Delta V as a Burner Management System in the production of Oil and Gas in the Gulf of Mexico, in particular Fired Components for Gas Dehydration Systems and Oil Heater Treater Systems.
  • DeltaV SIS is a good product solution. Lots of options in hardware and programming. Is it going to be standalone systems or integrated?
  • In reply to Jason.Brumfield:
    We will be looking at both Stand Alone and Integrated systems some platforms manned and some unmanned.
    On the unmanned facilities we will be using wind and solar power, therefore if any AC Power is required we will have to beef up the Solar and Wind with to accommodate an inverter.
  • Steve, as Jason indicates DeltaV SIS is a proven BMS solution. If you'd care to share your contact information, or email me directly at [email protected] I'd be glad to put you in touch with one of Emerson's contacts that could provide you with some information.
    Pete Kline
  • In reply to Pete Kline:
    Pete,
    I sent you an email. Thanks for responding. Burner Management Systems on a platform present different challenges.
