Module Alarm Parameters
Hello,
I am trying to access certain values located within a Module Alarm.
I was able to figure out how to access certain attributes of the Alarm such as the State, Enable, Inverted, Priority, and Functional Classification.
Example for HI_HI_ALM:
Enable = <Module>/HI_HI_ALM.ENAB
Inverted = <Module>/HI_HI_ALM.INV
Priority = <Module>/HI_HI_ALM.PRI
Function Classification = <Module>/HI_HI_ALM.FUNC
What syntax should I be using to extract the following Module Alarm Attributes:
Parameter
%P1 parameter
%P2 parameter
Any help will be greatly appreciated!
