Delta V reporter Issues
I am having issues regarding Delta V reporter service in Delta V Ver 13.3.1.
when i create a new report definition and try to schedule a report, it gives me the following error:
Kindly explain the origin of this error and how we can remove it? An error report is also attached in the text document.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IndexOutOfRangeException: Index was outside the bounds of the array.
   at DvCHXLA.ScheduledReports.ScheduledReportsDialog.displayScheduledTasks(Boolean resizeForm)
   at DvCHXLA.ScheduledReports.ScheduledReportsDialog.btnSchedule_Click(Object sender, EventArgs e)
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.7.3101.0 built by: NET472REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
DeltaV.Historian.Excel.AddIn
    Assembly Version: 13.3.1.6290
    Win32 Version: 13.3.1.6290
    CodeBase: file:///C:/Program%20Files%20(x86)/Emerson%20Process%20Management/DeltaV%20Reporter/DeltaV.Historian.Excel.AddIn.DLL
Extensibility
    Assembly Version: 7.0.3300.0
    Win32 Version: 7.00.9466
    CodeBase: file:///C:/Windows/assembly/GAC/Extensibility/7.0.3300.0__b03f5f7f11d50a3a/Extensibility.dll
office
    Assembly Version: 14.0.0.0
    Win32 Version: 14.0.4760.1000
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/office/14.0.0.0__71e9bce111e9429c/office.dll
DeltaV.Historian.Utility
    CodeBase: file:///C:/Program%20Files%20(x86)/Emerson%20Process%20Management/DeltaV%20Reporter/DeltaV.Historian.Utility.DLL
Microsoft.Office.Interop.Excel
    Win32 Version: 14.0.4756.1000
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.Office.Interop.Excel/14.0.0.0__71e9bce111e9429c/Microsoft.Office.Interop.Excel.dll
System
    Win32 Version: 4.7.3056.0 built by: NET472REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
DeltaV.Historian.ExcelAddInSupport
    CodeBase: file:///C:/Program%20Files%20(x86)/Emerson%20Process%20Management/DeltaV%20Reporter/DeltaV.Historian.ExcelAddInSupport.DLL
DeltaV.Historian.ResourceUtility
    CodeBase: file:///C:/Program%20Files%20(x86)/Emerson%20Process%20Management/DeltaV%20Reporter/DeltaV.Historian.ResourceUtility.DLL
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
CustomMarshalers
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/CustomMarshalers/v4.0_4.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Moreover, the "Scheduled Report" icon in the Delta V Excel Add-in does not work when we try to schedule a report again. (does not respond)
Kindly guide how we can successfully create and run a Delta V report.
