Dear All,
Deltav Ver. 13.3.6
We are facing a problem with error codes : C0040006(The item’s AccessRights do not allow the operation) in OPC Mirror Diagnostics. we have given all necessary privileges to the user. also we can fetch the data from 3rd party opc server, but the data unable to write in deltav control module. Screen shot is attached for reference. Please help to get the solutions.
Roshan,
Is your OPC Mirror is running on an Application Station? If you look at the properties dialog make sure the option "Restrict on-line changes to areas assigned to the Alarms And Event subsystem of this station" is unchecked. For Application Stations being used for OPC connectivity and batch executive nodes this option should not be checked. If you make a change you will need to download setup data to that application station. See the circled item below.
In reply to Scott Thompson:
In reply to Roshan Parte:
