I have a custom Detail display that was built from a DDC faceplate FB. In run envirionment the heading in the title bar shows up as Faceplate FB. I want that to read Detail, like the rest of my Detail Displays, but I can not figure out where the heading is decided when it's opened. Haven't found anything in scripts or properties.
Thanks
Search for frszDvsysIAfbInit and then change this to frszDvsysDetailInit, this should be int he CFixPicture_LoadedTagGroup event.
You should also check that you have the following (which I doubt and add this if you don't have):
Private Sub CFixPicture_SelectionChanged() On Error GoTo ErrorHandler frszpicCurLink Me.ContainedSelections, ps_CurrentLink Exit SubErrorHandler: frsHandleErrorEnd Sub
The mouse down event logic should also probably change to be consistent with Detail:
Private Sub CFixPicture_MouseDown(ByVal Button As Integer, ByVal Shift As Integer, ByVal X As Double, ByVal Y As Double) On Error GoTo ErrorHandler If Button = vbKeyRButton Then 'Track #36546 - Removed IEPOP1 on : 12/3/01 frszCreateAnEPMMenu Me End If Exit SubErrorHandler: frsHandleErrorEnd Sub
