I have a Horizontal 2 monitor Setup. I want Deltav Operate to only open on a single Monitor (preferably the right monitor).
I have tried manipulating the UserSettings.grf File and layout files.
I got Graphics to only load on 1 monitor but the Operate Program still takes up both monitors. The other monitor just has a blank gray background and no graphic.
I can resize the window to only 1 monitor but when i switch between Edit and Run mode the Operate Program goes back to using both monitors.
Is there any way to limit DeltaV Operate to only 1 monitor?
There's a setting in Usersettings that forces Operate to only one monitor. It has worked for me on my Simulate system. Never tried it on a Production system.
' Multi-Monitor INITIALIZATION ' ' Note: You can ignore this section for single monitor systems (i.e. multi-monitor ' functions will already be disabled). ' ' To disable multi-monitor functionality when using dual-monitor or quad-monitor ' hardware, uncomment the following line. This results in DeltaV Operate opening ' pictures only on one monitor. Only one toolbar, alarm banner, and main picture ' appear. You can still use the other monitors for other applications. ' ' frsVariables.gn_mh_disabled.currentvalue = 1
In reply to JoshC:
