Dear specialist
I have installed an additional AO card, 8 ch, 4-20 mA, Hart, Series 2 in order to control some speed converters. We have installed the wiring to the converters simularly as the existing. The card is found via auto sense and is downloaded to the controller, O
When the channels are enabled, we got the following failure Bad device failure, open loop detected.
We checked the wiring and that seems okay, because we checked this with installation of the speed converters with an AO card already in operation. That seems to function very well.
We are using professionalPlus software v12.3.
Does have anyone an idea what could be the problem?
If you have a solution for our problem, I will appreciated very well. Thank you in advance.
Best regards,
Elwin Gansekoele
In reply to Mike Link:
