Hello everyone, I'm considering changing the default Administrator account password in the Delta V system that we have installed in our site for security reasons. We are in a workgroup environment; I know that this arrangement is not recommended and I am already considering going back to a domain, but in the meantime I hope you guys can help me with this. I know that I should set the password to be the same on every computer because doing otherwise may create conflict in some services, but is there anything else that I should be worried about before making the change?
Many thanks for your invaluable help.
Do not change the password using anything except the DeltaV Workstation config or the setpass utility. This will ensure that all services are running and with the correct credentials after the change. The only other thing to worry about is any third party applications that access data from DeltaV (OPC, PI and Others) If you have installed these they may be configured with the DeltaVAdmin account and then would have to be updated also.
This was discussed here also.
In reply to DXSANCH:
