Diagnostic Parameters and OPC
I would like to bring some controller diagnostic parameters into my Pi system so I can use email to notify maintenance personnel of controller issues. I was looking to use the OInteg and OLInteg parameters to create the notifications. I used an OPC client to navigate the diagnostic parameter and noticed the top level, Restart and Redundancy parameters were exposed but not Communication. Is there a way to get the communications diagnostic parameters with OPC?
I have DeltaV 13.3.1
  • I am not sure why you are unable to browse, but you can find the correct parameter paths from DeltaV Diagnostics. Go to the parameter you'd like to fetch, right-click and select Properties. The window will show you the path. e.g. Overall Communications Link Integrity is [server]/COMM/PRI/OLINTEG
