I am working on a project with DELTA-V Process Control.
all of Anlaog Inputs are FF based but for a few loops , We need to have regular 4-20ma AO (to control drive speed) based on level transmitters (which are FF). We are thinking to use FF to 4-20ma converters. But I need suggestions on what is the best method to deploy this Loop? Can i add standard AO card in the system and send the speed control to drive from there bases on the analog inputs from level transmitters on FF segments? Or should i use the signal
conver to just convert the FF AO to 4-20 ?
