Version Control Checked out
Is there any easy way to see everything a certain user has checked out in Version Control?
Thanks in advance.
  • in deltav explorer if you select the top level of tour database then goto tools 》》version control 》》 history report
    you can generate a report for a specific data range just to sure to check recursive so it drills down.
  • An alternative just to see the list of items checked out would be to click on the top level of the database and go to Tools > Version Control > Search. In the search dialog, you can search for items checked out to a specific person only. This will bring up a dialog which has the list of all things in your search in which you could check in multiple items at once here.
