Hi all,
We have a unique situation at our plant in which we have two separate trains of equipment that have a unique batch recipe that runs on each. As both of these trains make the same end result product, their batches are named the same except for the number of the batch at the end. One train uses even numbers and the other uses odd. We have issues (happening more often here lately due to new recruits) in which the operator incidentally skips the next batch number and creates the one after. For example, if the next batch were suppose to be 129, the operator skips this and creates batch 131 which throws production off when they go to do material balances, etc. Is there any way in which you can have the field prepopulated with the next batch ID when the operator goes to create the batch? One step further, is would there be a way to make this work with the even and odd numbering scheme we are currently using? If there is no way to prepopulate this field, is there a way to restrict the batch ID that is entered to where we would only let them enter the next number?
Thanks and any help is much appreciated!
