Change Detail Picture Size
I needed to create a new detail so I used another existing detail as my starting point. I want to modify the picture height of my new detail but whatever height I choose is not retained after I save, close, and reopen. I am attempting to change the height through the Edit Picture dialogue and the Window Height property.
What do I need to do to modify the height of a detail picture? Are there only certain heights that I can use? If so, what are they?
  • You need to be setting the DocumentHeight and DocumentWidth properties which can be seen when you open the picture, right click with nothing selected and select "Property Window..."
    Regards.
    Matt
