Hi all,
I am using delta v version 11.3.1 with SIS. I am facing a critical problem with analog inputs.
I have 33 redundant SLS cards. In that my SLS no. 13/15 having a problem.
it consists of
4 analog inputs
5 Digital outputs
7 digital inputs
If I connect all DI and DO signals, then the card is normal. I checked diagnostics also except 4 analog inputs everything is working fine.
But if I connect any AI signal, within 2-4 minutes the "standby" card is getting bad and showing error also the diagnostic showing partner not available.
The "active" card is working fine.
During the rectification I changed SLS and termblock also.
Please help me to fix this problem
Your help is highly appreciated .
Best Regards,
In reply to Rachelle McWright:
