I run a DeltaV Simulation machine (10.3.1) in a Virtual Machine.I need to load the configuration for a plant containing a lot of interconnected units. For this reason it is preferred to load a great part of the plant configuration.Now I am running to a limit in memory. My simulation machine reports at partial download: ERROR: There is not enough memory to perform the operation. 1. I extended the disk space - no extra capacity.2. I extended the Virtual memory - no extra capacity.In Diagnostics I see that for the ProPlus in the simulation machine the FreeMem starts at 128 MB for no configuration, decreasing at each download. Apparently this 128 MB is set bij DeltaV.
Is there a possibility to extend the assigned memory, so I can load extra configuration?
In reply to Mark_ORosky:
In reply to Ray Emerson:
In reply to Maarten van der Waal:
