How do I export data to Excel from Legacy Historian
Does anyone know how to export data from the Legacy Historian to Excel? I'm running v10.3 and don't have the Excel Reporter function. I tried to load the Excel Add-ins but they don't work either.
  • I assume you mean you tried to load the PI Excel Add-in on a DeltaV node?  Why did this not work?  (What errors did you get?)
    In 2006, I wrote a batch file to perform this task (we didn't have the PI tools).
    The principle is to
    1. Create a piconfig commandfile.
    2. Run piconfig with the commandfile as input.
    3. Return a .csv as output.
    The command file should look like this:
    @prom n
    @table piarc
    @mode list
    @istru tag, starttime, endtime, count, mode
    @output %Out%
    @echo data
    @ostru value, status, time, tag
    @ostru ...
    %Tag%, "%Startdate% %Starttime%", "%Enddate% %Endtime%", %Count%, %Mode%
    @exit
    where
    %Out% = Output file path/name (remove quotes)
    %Tag% = tagname
    %Startdate% = starting date formatted correctly
    %Starttime% = starting time formatted correctly
    %Enddate% = Ending date formatted correctly
    %Endtime% = Ending time formatted correctly
    %Count% = maximum number of expected records
    %Mode%= retrieval mode, I suggest Comp
    Then run piconfig through batch script on your historian, using the command file as input.:
    piconfig -remote -node %NodeName% -port 5450 -username %Username%<%InputFile%
    where
    %NodeName% = PI historian name
    %Username% = PI User
    %InputFile% = Command File Name
    I would refer to the PIConfig documentation for specifics. The output file should list the record fields as comma-separated values per the ostru.
    Hello. I represent SyTech which make XLReporter. As an Emerson partner we offer read/write functionality from OPC and historian to workbooks without needing Excel. I am assuming your question is around the continuous historian and, if so, we offer you a "out-of-box" solution. Scheduling and ad-hoc reporting is built-on. If you are interested, visit www.sytech.com for a free evaluation or contact me for futher assistance at 508 520 9957.
