Hello Everybody,
first that all sorry about my english, the problem that I have is the Next:
Have a Application Station with OPC Mirror I made the configuration with the .cfg exported from de ProPlus, When I Run the OPC Service have a lot of time starting but it can't, and when a try to open the configure windows it close inmediatly, Please may you help me, what I'm doing wrong.
Thanks.
In reply to AdrianOffield:
Is mirror licensed for the application station you have installed OPC mirror on?
Yes I put the license "OPC Mirror 2 Servers" in the PPLUS and after that I assigned it to the APPSTATION (thats the Windows name I gave it to the stattion)
What do you mean by .cfg file, are you referring to “Create Station Configuration File” (DevData.cfg)?
Yes, thats the file I mean.
Which OPC service are you referring, OPC Mirror perhaps? Do you have a task tray icon for OPC Mirror?
I made right click in the OPC Mirror Tray and select "Start OPC Mirror Service" The system ask me: "Starting OPC Mirror Service will start all enabled pipes, Doyou want to continue?" I select YES but takes a lot of time and says "Startting OPC Service Please Wait", but the service not starts.
Adrian Thank you so much for the support,
I will try to connect the Deltav OPC with the Tank master OPC, I have installed Tank master and after I installed the OPC Mirror, maybe I should uninstall the Tank master?
I have unistalled a re-installed many times the OPC Mirror but unfortunately the same results, I have a doubt when I'm installing the OPC Mirror the system askme "If you are on deltav system you must specify the deltav account, if the account is not currently a DeltaV account, you can create the deltav accvount in the deltav user manager", for this issue I was using:
Password: deltav
and
but it doesn't work with this two loggings.
