My application station is "not communicating" according to User Manager and other tools like DeltaV Delete Utility. When I try to open User Manager on the AS it says it cannot communicate to the database. When I run Update Dynamos, it says it can not get graphics files from AS/ folders. When I run DeltaV Delete Utility I get a similar warning about not being able to communicate. Within Explorer everything is communicating and shows up perfect. I even reran Workstation Configuration with a new DevData.cfg file and I have the same problem. I had previusly had problems communicaiting with the other servers in User Manager, but I started the Computer Browser service and the terminal services could then replicate accounts. But, the AS still won't connect in User Manager. I can't open it on the AS and also on the Proplus, it lets me select the AS in User Manager, but after some delay i get an error that it can't connect to the server.
Thanks in advance.
resurrecting this.. does anyone have an idea? I still have this problem. Maybe this is normal ?? Maybe AS doesn't use user manager in the same way and maybe since it's not meant for being a workstation the graphics aren't supposed to copy across?? But, I don't recall this happening elsewhere,, I'm going to test it at a different site.
In reply to TreyB:
