EE - Forum Styles
fo
How to delete a tag from AMS Device Manager?
After some difficulties replacing a FF flow transmitter, we ended up with another tag in AMS, appended with _01. I can't figure out how to remove it.
  • On the AMS server, in the Start Menu, under AMS device manager header,there is an option to "Remove the device", You can delete the Device tag there, You need to disconnect all the clients from the server before you can Remove/delete the old device else you wouldn't be able to remove the device.
