Bluetooth Temperature measurements interface to AMS 2140
If your AMS 2140 is under Guardian Support, it entitles you to the latest firmware for the AMS 2140 which adds Bluetooth support for temperature readings using the 377BT Bluetooth Temperature Gun from TPI. This handheld device enables fast, accurate temperature measurements across a wide temperature range with the results automatically stored in your AMS 2140 - in either Route or Analyze!
This custom interface will allow you to benefit from the following features:
  • Non-contact measurement with laser sight
  • Spot ratio better than 10:1
  • Measurement range from -18 to 1000⁰C (-58 to 1,832⁰F)
  • Accurate readings (+2⁰C or +2%)
  • Adjustable emissivity
