AMS OPC Server and Fisher DVC
Hi Guys,
Has anyone had experience with obtaining status info from a DVC via AMS OPC Server? I can access the deice but there is a ton of parameters to choose from!
I need to pull back a consolidated device alert status from the valve.
Any help appreciated.
  • Hi Adrian,
    I am with the FIELDVUE Marketing and Support team.
    The information you are inquiring about the status information is available from a DVC instrument via OPC but is spread over several parameters which will require some numeric conversion to extract. Bear with me as I attempt to explain.
    The "device status" information of a DVC is contained in seven bytes worth of binary data. The OPC parameters portraying these bytes are:
         device_status
          xmtr_specific_status_0
          xmtr_specific_status_1
          xmtr_specific_status_2
          xmtr_specific_status_3
          xmtr_specific_status_4
          xmtr_specific_status_5
    with the "ValueAsString" for each of these parameters being a decimal number 0 through 255.
    If you convert each of these decimal numbers to its eight-bit binary equivalvent you end up with eight bits where each bit has a defined meaning of an individual alert or status condition. The definition of these bits is documented in a FIELDVUE Instruction Manual Supplement document number D103266X012. This document can be downloaded from the followijng website by searching for this document number:
       www2.emersonprocess.com/.../DocSearch.aspx
    The "Device Status" information is available in a table on page 2 of this document. The "xmtr_specific_status" bytes are defined by byte as bytes 0 through 5 in the "Command 48" section starting on page  8.
    For example, if the ValveAsString for "xmtr_specific_status_4" from a firmware 7 DVC6000 has a value of "9", the meaning of this value is obtained by converting "9" to a binary valve of 00001001 and then checking in" Table 48-4B Status Integrity Byte" for a DVC6000 firmware version 7 (on page 10 of this document) for what these bit mean. "00001001" translates as "Travel Deviation Alert" and "Drive Signal Alert".
    If you have additional questions or have problems obtaining this FIELDVUE Instruction Manual Supplement, please contact your local Fisher Controls Valve Sales Representative office or reply back to me.
    I hope this clarifies the issue for you!!
    Jeff
  • Great Information Jeff V.  Adrian what exactly are you trying to accomplish?  I ask because there may be a single paremeter that gives you what you need.
  • Is anyone out there utilizing the AlertTrack Snap-On for AMS Device Manager?  If so,  are you applying it to customized alert groups and notifying individuals via email and mobile alerts?
    Joel Holmes
    Site Reliability Engineer - Electrical
    Monsanto Co. - Muscatine, Iowa
    563.262.7370
    This e-mail message may contain privileged and/or confidential information, and is intended to be received only by persons entitled
    to receive such information. If you have received this e-mail in error, please notify the sender immediately. Please delete it and
    all attachments from any servers, hard drives or any other media. Other use of this e-mail by you is strictly prohibited.
    All e-mails and attachments sent and received are subject to monitoring, reading and archival by Monsanto, including its
    subsidiaries. The recipient of this e-mail is solely responsible for checking for the presence of "Viruses" or other "Malware".
    Monsanto, along with its subsidiaries, accepts no liability for any damage caused by any such code transmitted by or accompanying
    this e-mail or any attachment.
    The information contained in this email may be subject to the export control laws and regulations of the United States, potentially
    including but not limited to the Export Administration Regulations (EAR) and sanctions regulations issued by the U.S. Department of
    Treasury, Office of Foreign Asset Controls (OFAC).  As a recipient of this information you are obligated to comply with all
    applicable U.S. export laws and regulations.
