Velocity Gain
The definitions provided in the manual are absolutely useless (Below I copied them out the manual)
Can you please post the definitions of the items below?
Proportional Gain—the proportional gain for the travel control tuning set. Changing this parameter will also change the tuning set to Expert.
Velocity Gain—the velocity gain for the travel control tuning set. Changing this parameter will also change the tuning set to Expert.
MLFB Gain—the minor loop feedback gain for the travel control tuning set. Changing this parameter will also change the tuning set to Expert.
Integral Enable—Yes or No. Enable the integral setting to improve static performance by correcting for error that exists between the travel target and actual travel. Travel Integral Control is enabled by default.
Integral Gain—Travel Integral Gain is the ratio of the change in output to the change in input, based on the control action in which the output is proportional to the time integral of the input.
  • Garrett, The definitions in the manual are accurate. It will help if you can describe what you are trying to do and where you are having trouble. Alternately, you could contact the impact partner who supports you for help tuning the valve assembly.
  • Hi Garrett,
    If you need more detailed explanation on above parameters, there is white paper providing clarity on it. You may please contact Local Emerson Impact Partner in your WA, who will be able to support your need. Or send me email ([email protected]) and I will forward white paper for your perusal.
