Explain the terms outlined below
Hello house, i will need a detailed explanation of the following terms of a magnetrol level Hart transmitter.
1. PV out of limits.
2. Non-PV out of limits.
3. Loop current saturated.
4. Loop current fixed.
5. Cold start.
6.Configuration changed
7.device malfunction.
8.Device variable alert.
9.Critical power failure.
10.Software failure.
11.cpu failure.
12.EEprom failure.
13.default params.
14.Loop failure.
15.No end of RAmp.
16.Fiducial shift.
17.slope error.
18.No probe.
19.No fiducial.
20.Safety zone Alarm.
21.No signal.
22.Seal leak.
23.Fiducial spread.
24.Calibration
25.EOP too low.
26.Trim required
27.Initializing
28. May be flooded.
My email address is [email protected], thanks for your much anticipated assistance.
  • Hi Plato,
    I can see that you specifically asked for Magnetrol transmitter's alerts terms. Unfortunately we are unable to advise. You may consider looking up their website: us.magnetrol.com/Product_Landing.aspx
    If you are looking for a level solution on your level application, feel free to share your application here and the group will try to suggest a solution with Emerson's experience.
    Thanks.
    Kee Chong
