Recent Measurement Instrumentation Discussions
sludge
12 Sep 2012 9:08 AM
sludge flow meter - shutdown
Jim Cahill
29 Aug 2012 4:55 AM
Soft Seat Material In Daniel Orifice
Riza Galang
28 Aug 2012 9:51 AM
Need help in Coriolis Mass flow meter for High temp application
Jim Cahill
27 Nov 2011 1:45 PM
Award-Winning Presentation: LNG Dispensing Made Simple Using Micro Motion
Jim Cahill
14 Nov 2011 12:18 PM
How to videos in the Micro Motion community
Flowboss s600+
Flowboss s600+
floboss S600 +
Save browser password for S600 Flowmeter
Density Failure Modes on the Original Floboss S600
Answer Suggested
Flowboss S600+
Dear sir,
Hope you are well,
please be informed that we have 2 flow-computers FlowBoss S600+ under project Emerson P.O. Ref: 97151018. Suddenly the web base browser can't be accessed as once I logged in, the server logged out.Try more times to enter, always session logout message appears.I tried to connect directly to P152 board (CPU) for both Ethernet ports found i can ping but also no access can be occurred.This trails was performed by two PCs as a double check.Please see attached video inside link below for more info.
filebin.net/r5fo776nh0mhm9un
Note: i perform compatibility setting at internet explorer with no gain.
ian firth
11 Jan 2021 11:07 AM
We made some modifications to the binary files a while ago to help alleviate these issues and you should have received details via supportnet. The most common reason is that you have some other task using the resources and the web server is a very low priority task controlled from the linux kernel and not the s600+ code directly. All we can suggest is to first power cycle the unit as this will restart all the linux tasks and then consider upgrading the binary file to the later releases but also check other connections you have tot he ethernet which is probably your supervisory and see that it is polling for the correct data
hashem ali
11 Jan 2021 2:49 PM
ian firth
Firstly, thanks for your fast reply.
Can you help me to get more details from supportnet?
I will start power cycling and see the results...
ian firth
11 Jan 2021 3:21 PM
hashem ali
www3.emersonprocess.com/.../main.html
If you do not have an account please sign up, it is a free service. it will give you access to the latest binary files along with release notes as well as any safety release information we have issued in the past. You can then add tickets ( questions ) on there and we will be able to assist you easier than though exchange
