Recent Measurement Instrumentation Discussions
Jim Cahill
26 Aug 2014 5:12 AM
electromagnetic flow transmitter error
Rossella Mimmi
13 Aug 2014 10:01 PM
How reproducible is your highly repeatable metering system?
amir
8 Aug 2014 11:06 AM
hello i need a flow transmitter can any body help me on this matter thank you
daviesjj
19 Feb 2014 6:13 AM
AGA3 and ISO5167 - MOVED TO DELTAV FORUM
chandu
29 Nov 2013 4:16 AM
Mass flow cut off and Live Zero monitoring significance
Multipath SeniorSonic Model 3400 USM Hardware Fail Alarm
USM WET CALIBRATION
Premium billing mode on USM meters
Daniel USM 3414 SOS Alarm can not be Acknowledged/Cleared
Question related to Model 1700 & 2700
USM model 3400 (SN-150005003)
Dear all,
Please be informed that suddenly USM reading was oscillated between the actual reading and zero. Therefore, there are some troubleshooting steps were performed to solve the problem:
1-
Connect laptop direct through
Daniel MeterLink
software found the software cannot establish communication.
2-
Reset power on flowmeter found the communication is established.
3-
After accessing found 3 current alarms as shown at attached pic (USM1).(in my opinion the first alarm is the main cause of this problem as the reading of pressure and temp. for this branch were in the accepted range).
4-
Approx. 20 seconds ago, found a pop up message said there is a communication error and the communication fail. (If a power is cycled, the communication will be established again for the same period and then stopped.)
Note:
The rest of attached pics as a guide to reach the root cause of this problem.
Your kindly support is highly appreciated.
hashem ali
28 Jun 2019 8:52 AM
Please help me in the above issue as it is urgent case
