Hi ,
I have a few questions based on my interaction with clients ,
1 - Customer has a sale & check meter (coriolis) connected in series for custody transfer application & informed that both these reading were not matching,Please explain what might be the possible reasons
for this mis match
2- When a meter is supplied from the factory what is the calibration validity time
3- what is difference between meter factor & k factor & are there any conditions & situation when an operator can change it ?
4- When there are 2 pulse outputs from a transmitter with 90 degree phase shift , what is it signifying ,like kind of if one pulse output not working the other takes it place
is it right understanding?
5- If a customer has an RS 485 output from transmitter ,then it can be possible to fetch multi variable data like volume,mass,temperature from the transmitter using a single RS 485 Communication signal to connect to host system ,is it right ?
Looking forward for these answers
Thank you
Yunus Misbah
