I have a CMF050 Sensor hooked up to an RFT9739 Transmitter. I'm transmitting the analog (non-HART installation) PV (mass flow) and SV (density) from the respective output terminals and am interested in getting the temperature from the CMF050 as well. The RFT9739 has output terminals labeled for temperature (23 & 24). Are these output terminals associated with the connected sensor, internal electronics or are they some other temperature? Also, is this temperature signal RTD-analog or 4-20mA? I'm not finding much in the documentation that explains the purpose of the temperature output terminals. My work around for this is to disconnect the violet-yellow-orange RTD wires from the RFT9739 altogether and extend them directly to an RTD IO card.
In reply to Cara Wilmer:
