I have this H050 flow sensor using 2500 transmitter. May I know what are the parameter that I need to change from the default setting?
I'm using HART communicator for this.
I did changed the mass flow unit to grams/min which is what we prefer, and also the URV (136,078g/min) and LRV (0 g/min) base on the given max flowrate of H050 which is (300lb/min = 136,078 g/min).
We have a linearity issue on lower flowrate (<500 range) so let me know what might be the parameter that I need to change.
Thank you,
Niklas Flykt
Klinkmann Oy
[email protected]
In reply to Niklas Flykt:
Niklas, if the flow set point are less than 500, there's a 50 grams discrepancy with water as medium. Anybody here did configure the same device? kindly send me how you made changes on parameters as my reference. thank you,
