Script editor
Hi All
Could you please support me , i try to write script on the graphic for open the Excel sheet when I press on push button on graphic i tried to write the code but it ha ve error ,please see attached snapshot, Looking for your support
  • IIn your printscreen you try to run directly the excel file....you have to run Excel Application with your file as parameter..
    It 's done like this ( The path of Excel.exe file must be adapted to your case
    frsruntask "C:\Program Files (x86)\Microsoft Office\Office16\EXCEL.EXE c::\.....yourexcelfile.xlsx"
  • You could try something like this.
    Call Shell("cmd.exe /S /K" & "YOUR PATH", vbNormalFocus)
    'After your is file opened, you should close the cmd window.
    TaskKill = CreateObject("WScript.Shell").Run("taskkill /f /im " & "cmd.exe", 0, True)
  • In reply to Nicholas Stom:
    I used same code but same error still appear
  • Use these code but still same error appear
  • In reply to Hassan.hameed:
    Can you please post the code?
  • In reply to Lun.Raznik:
    Code and error code
    To get accurate error code put the following line in the errohandler section :
    Msgbox (error)
  • I update the snapshot please advise
    if you wanted to continue to use frsRunTask, you have to do it like:
    frsRunStartTask "C:\windows\system32\notepad.exe", "C:\MSSQL2K\MSSQL13.DELTAV_CHRONICLE\MSSQL\Log\ERRORLOG"
    Notice the comma and quote the path properly.
  • What reply means into your code ?
    The path of your file is wrong
    And we don’t see the end of line, don’t forget the “
  • In reply to LaurentB:
    It seems you have a small experience with VBA, and i want to warm you that behind the keyboard there is a plant. It could be dangerous to make code without good practices skill. Don’t you have a VBA engineer closed to you to guide you ?
    Hi Thanks for replay ,the costumer want to add button in Graphic if we press this button the Report excel sheet appear could please help me to do that
    The VB code provided to you is working well, just copy it with attention and take care about the path of the file . Path must be adapted to you own location file.
    Into prinstcreen you provide I see at least 2 mistakes....
    I See "Reply" in the code ....what is it ?
    I see that the path of the file start with / without the begining of the path c:/ ...
    I don't see the end of line so I suppose this line is well terminated by the double quote signe " . ( this is the single double quote ", not 2 times the single quote '
    The following line works as charm, but you must have no other wrong line in VBA and modify the exact path of files
    frsruntask "C:\Program Files (x86)\Microsoft Office\Office16\excel.exe C:\Users\myname\Desktop\book1.xlsx"
    As Lun said the following line works also
    frsruntask "C:\Program Files (x86)\Microsoft Office\Office16\excel.exe", "C:\Users\myname\Desktop\book1.xlsx"
    Again adding a simple button in graphic could be dangerous if it's made by a beginner, the wrong code can have consequences on process control. Behind the keyboard you control a plant, not only a file as office application....
    Many Thanks of advise the wrong with path, is this document from Emerson can help me to understand the VB
    Depending of where you are located you can contact directly Emerson training centers, They can propose a various courses for each cases.
    www.emerson.com/.../educational-services
