5474 subscribers
Rein
29 Nov 2021 2:27 PM
spaul-WME
19 Nov 2021 4:58 PM
John Rezabek
11 Nov 2021 2:35 PM
Senthilkrishnan M
10 Nov 2021 12:09 PM
ktidke
9 Nov 2021 5:22 PM
I am looking to control a Powerflex 753 drive with a 32 bit DINT
FFDI block - accessing the data byte
Split Range Setup
Split Range Controller Tuning
split 32 dint to 8 -byte
Hello,
i need to split 32 dint to 4 x 8-byte integers. Could someone help me?
Greetings.
Maarten van der Waal
9 Jan 2019 5:50 PM
Look in the question "How to Map 32 bit data in Deltav" for your answer.
For your subject the 32 bits is split into 2 * 16 bits, but using the methods described you can easily split into 4 * 8 Bits
