5482 subscribers
Robin
26 Aug 2022 4:32 PM
DeltaV alarm Operation
Bryce Elliott
24 Aug 2022 1:56 PM
External NTP Server
Kunal
23 Aug 2022 1:47 PM
Error Number : -1577058273 (A200001F)
19 Aug 2022 8:31 PM
Graphics not updating on Thin Client/VM
Ryan Black
19 Aug 2022 4:02 PM
User.fxg giving VB Out of Memory error while programming
How do I configure a PIN (Pulse Input) function block for shaft RPM.
DI as Pulse Input (PIN) for belt speed
deriving a flow rate from a pulsed input - is the Pulsed input function block the right block for this application?
Timed Pulse Function Block
Turbine Flowmeter Pulse Input to DeltaV
How do I wire pulse device to a Series 2 Multifunction I/O Card installed in backplane as card #5 with an MDPlus controller.
The pulse generator is a CAT magnetic speed pick up generating up to 2500HZ, voltage of 12Vac across its terminals. Do I wire this directly to the multifunction card via an SD32 barrier just like that? I have one speed sensor wired this way to terminals 25/26 of the I/O card but it seems not to record any frequency at the DCS. Please help.
