I am not exactly figure out scaling in AI block for conventional transmitter.
I want to know how Field_Val (unit %) is calculated for different L_Type.
My understanding -
1. xD_SCALE low scale value = value for 4mA current and high scale value = value for 20mA filed current.
2. In Direct scaling,OUT = FIELD_VAL% of OUT_SCALE where OUT_SCALE is copied in xD_SCALE means (What will be value in FIELD_VAL parameter and how it will be calculated).
3. In indirect scaling, OUT = FIELD_VAL% of OUT_SCALE where FILED_VAL = how much % of filed current is w.r.t. xD_SCALE.
4.In square root scaling and In direct independent scaling ...........................????
Thankyou
Have you looked in DeltaV Books Online?
Your items listed in 4 are typically used when an orifice is being used for Flow (and a transmitter doesn't already account for this) for Ind Sqr Root and when RTD/Thermocouple inputs are used for Direct Indep (Not Indirect independent).
In reply to Matt Stoner:
Thanks Matt for your valuable response,I am referring to Book online and block configured for our plant operation,Today i was again trying to understand it and concluded following :- (Following are for conventional NON-HART 4-20ma transmitter). (OSH = OUT_SCALE_HIGH and OSL = OUT_SCALE_LOW) (FILED_VAL_PCT = M% in every case) 1. Block execution flow is Finding FILED_VAL_PCT (Unit=%) = the % of channel loop current w.r.t 4-20mA current range -------> Calculating FIELD_VAL (Unit = %) ------------> Calculating PV (unit = unit of OUT_SCALE) ---------> Calculating OUT 2. For L_TYPE = Direct scaling FILED_VAL_PCT (Unit=%) ------------> FIELD_VAL = M% of XD_SCALE (Where XD_SCALE will always be same as OUT_SCALE) --------> PV = FIELD_VAL% of OUT_SCALE --------------> OUT = PV (Considering mode is Auto) 3.For L_TYPE = Indirect scaling FILED_VAL_PCT (Unit=%) ------------> FIELD_VAL = M% of XD_SCALE --------> PV = FIELD_VAL% of OUT_SCALE --------------> OUT = PV (Considering mode is Auto) 4. For L_Type = Indirect sq.root FILED_VAL_PCT (Unit=%) ------------> FIELD_VAL = M% of XD_SCALE (Where XD_SCALE will always be same as OUT_SCALE) --------> PV = Sqrt( FIELD_VAL% divided by 100) * (OSH-OSL) + OSL --------------> OUT = PV (Considering mode is Auto) 5. For L_TYPE = Direct independent Still struggling to understand. My Point is Is my conclusion in point 1 is right ??????? IS other point 2,3,4 concluded are correct?? Matt i am truly thankful to you for sparing out your precious time.
In reply to Devpriy sahu:
